rgrver avatar image
rgrver asked
Calulating amp-hours from MPPT watt-hours?
I turned off my MPPT for several days and let my 100 Ah LiFePO get down to 13.1v with a small load. Turned solar back on and waited until it reached float stage (2+ days later). My MPPT stats say it took 1060 watt-hours to get back to full charge.
Now, I know watts are IxV. However, what should I use as "V" to calculate the total Ah needed to get back to full charge? Actually, the difference between 13.1 and 14.0 is only about 5 Ah (81 VS. 76), but I'm curious.
Thanks,
Ralph
MPPT SmartSolar
rgrver avatar image rgrver commented ·
@klim8skeptic
Took me awhile to see why you posted the photo. :) Thanks for it.
Ralph
Alexandra avatar image
Alexandra answered ·
@RgRVer
On lifepo4 you cannot use voltage at all to tell state of charge or used AH as their discharge curve it so flat and there is little difference between charged and flat voltage.
The difference of almost 1v can represent 50 to 100ah.
The formula for conversion is WH/V = AH.
1060 / 13 = 81AH (maybe slightly less as the voltage rises during charge and i assume you still had your load conneted at the same time?)
So your battery was 80% discharged if you charged up with no other loads connected.
Your battery full will have 100AH x 14v = 1040WH total capacity. This also it not cut and dried especially if you are not drawing the the c rating of the battery and of course the temperature the battery is installed in.
@Alexandra
Thanks for the info. I was aware of the flat discharge curve. Using 13 volts as an approximation makes sense.
Thanks, Ralph
