kaarthik avatar image
kaarthik asked
Zero feed in is still allowing some small amount of power to export?
good morning
i have configured ESS with zero feeding in enabled but it feed back some power daily ,even it is small power per day , if we consider for month and year its Too big,Please suggest me what is the issue or i was misunderstood,here below i have attached picture.zero-feedin.jpg
ESS
gromheisei avatar image
gromheisei answered ·
hello,
I have set it up, feed almost nothing!
kaarthik avatar image kaarthik commented ·
can you please check your dashboard ,here to grid is 2.7kwh which mean even i enable zero feeding its feeding 2.7kwh to the grid.i want to know how to stop this feeding.zero-feedin.jpg
kallenr avatar image
kallenr answered ·
how did you connect the solar inverter to limit the current to the grid?
I have an SMA-Sunny boy but I think it can only listen via modbus to the power generated by the sun (1-way communication)
He can't tell the SMA-Sunny boy to hold back.
4 comments
i have controll through MODBUS communication in ESS.Please find the link for the setup.
https://www.victronenergy.com/media/pg/Energy_Storage_System/en/configuration.html#UUID-634c2829-76e8-4e0a-522b-32bbe2cd1c92
kallenr avatar image kallenr kaarthik commented ·
I think you have a Fronius inverter, then I understand.
it is controlled via MODBUS,
Do you happen to know if I can limit another brand?
possibly connect the inverter to the AC1 output?
kaarthik avatar image kaarthik kallenr commented ·
yes possible with ABB inverter.
can you comment a little more extensively?
because I do not understand what question you are answering
and which ABB inverter do you mean?
