Erik Sporns avatar image
Erik Sporns asked
CB Radio disables SmartSolar 100|30
Hey guys,
i have a weird issue with my SmartSolar 100|30. Im running an EU-Standard CB radion (27mhz 4 watt), with an antenna on the roof of my van, next to my solar panel. Whenever im transmitting the charger turns off. Checking the status with victron connect shows that the charger is disabled in the settings. it turns on again as soon as im stopping to transmit. I does not matter if im running AM or FM. A similar powered hand held radio 2m away doenst trigger the issue.
Is this indented or did i find a bug?
MPPT SmartSolar
larry-1 avatar image larry-1 commented ·
Have you corrected the RF issue. I am having a similar problem. When I transmit my Multiplus 3000 shuts-down.
Erik Sporns answered ·
Update: cerbo gx connected temperature sensors are failing during transmit as well. They seem a bit sensitive to rf signals.
