Pavel Richter avatar image
Pavel Richter asked
MPPT strange logs
MPPT I have two connected to the octo GX.
Everything worked great. Chaotic error logs began to appear a few days ago. The MPPT is disconnected from the octo GX and reconnected in a few seconds.
Daily productions do not match on the VRM portal.
I have an FW current version in both MPPT and octo GX.
Any advice?
Solar Charger - MPPT 150/45 Jih [292] Automatic monitoring Error code: #6 - Battery voltage sense miswired (+) 2021-02-14 19:19:08 1s
Solar Charger - MPPT 150/45 Jih [292] Automatic monitoring Error code: #8 - Battery voltage sense disconnected 2021-02-14 19:09:41 2s
Solar Charger - MPPT 150/45 Jih [292] Automatic monitoring Error code: #1 - Battery temperature too high 2021-02-14 18:20:05 1s
Solar Charger - MPPT 150/45 Jih [292] Automatic monitoring Error code: #8 - Battery voltage sense disconnected 2021-02-14 16:06:32 1s
Solar Charger - MPPT 150/45 Jih [292] Automatic monitoring Error code: #2 - Battery voltage too high 2021-02-14 15:39:12 1s
Solar Charger - MPPT 150/45 Jih [292] Automatic monitoring Error code: #4 - Battery temperature sensor miswired (-) 2021-02-14 13:48:44 1s
Solar Charger - MPPT 150/60 Zapad [293] Automatic monitoring Error code: #8 - Battery voltage sense disconnected 2021-02-14 12:54:39 1s
Solar Charger - MPPT 150/60 Zapad [293] Automatic monitoring Error code: #2 - Battery voltage too high 2021-02-14 12:44:52 1s
Solar Charger - MPPT 150/60 Zapad [293] Automatic monitoring Error code: #4 - Battery temperature sensor miswired (-) 2021-02-14 12:31:02 1s
Solar Charger - MPPT 150/45 Jih [292] Automatic monitoring Error code: #4 - Battery temperature sensor miswired (-) 2021-02-14 12:25:51 1s
Solar Charger - MPPT 150/45 Jih [292] Automatic monitoring Error code: #2 - Battery voltage too high 2021-02-14 11:30:33 1s
Solar Charger - MPPT 150/45 Jih [292] Automatic monitoring Error code: #1 - Battery temperature too high 2021-02-14 11:04:03 1s
Solar Charger - MPPT 150/45 Jih [292] Automatic monitoring Error code: #2 - Battery voltage too high 2021-02-14 10:37:14 2s
Solar Charger - MPPT 150/45 Jih [292] Automatic monitoring Error code: #2 - Battery voltage too high 2021-02-13 15:32:33 1s
Solar Charger - MPPT 150/45 Jih [292] Automatic monitoring Error code: #8 - Battery voltage sense disconnected 2021-02-13 15:24:50 1s
Solar Charger - MPPT 150/45 Jih [292] Automatic monitoring Error code: #8 - Battery voltage sense disconnected 2021-02-13 12:41:47 1s
Solar Charger - MPPT 150/60 Zapad [293] Automatic monitoring Error code: #2 - Battery voltage too high 2021-02-13 12:39:26 1s
Solar Charger - MPPT 150/45 Jih [292] Automatic monitoring Error code: #1 - Battery temperature too high 2021-02-13 12:15:52 1s
Solar Charger - MPPT 150/45 Jih [292] Automatic monitoring Error code: #2 - Battery voltage too high 2021-02-13 11:45:06 1s
Solar Charger - MPPT 150/45 Jih [292] Automatic monitoring Error code: #6 - Battery voltage sense miswired (+) 2021-02-13 11:30:41
System overview Automatic monitoring DVCC Firmware insufficient alarm: Warning 2021-02-13 11:14:21 1s
System overview Automatic monitoring DVCC Firmware insufficient alarm: Warning 2021-02-13 11:12:25 1s
System overview Automatic monitoring DVCC Firmware insufficient alarm: Warning 2021-02-13 11:10:33 1s
System overview Automatic monitoring DVCC Firmware insufficient alarm: Warning 2021-02-13 11:02:21 1s
Solar Charger - MPPT 150/60 Zapad [293] Automatic monitoring Error code: #6 - Battery voltage sense miswired (+) 2021-02-13 10:33:44 1s
Solar Charger - MPPT 150/60 Zapad [293] Automatic monitoring Error code: #8 - Battery voltage sense disconnected 2021-02-13 10:27:54 1s
Solar Charger - MPPT 150/45 Jih [292] Automatic monitoring Error code: #4 - Battery temperature sensor miswired (-) 2021-02-13 10:23:10
Solar Charger - MPPT 150/45 Jih [292] Automatic monitoring Error code: #8 - Battery voltage sense disconnected 2021-02-12 23:17:35
System overview Automatic monitoring DVCC Firmware insufficient alarm: Warning 2021-02-12 22:32:42
System overview Automatic monitoring DVCC Firmware insufficient alarm: Warning 2021-02-12 20:55:53 1s
System overview Automatic monitoring DVCC Firmware insufficient alarm: Warning 2021-02-12 20:43:21 1s
System overview Automatic monitoring DVCC Firmware insufficient alarm: Warning 2021-02-12 20:04:28 1s
System overview Automatic monitoring DVCC Firmware insufficient alarm: Warning 2021-02-12 12:10:25 36s
System overview Automatic monitoring DVCC Firmware insufficient alarm: Warning 2021-02-12 10:15:30 2s
System overview Automatic monitoring DVCC Firmware insufficient alarm: Warning 2021-02-12 10:12:12 4s
System overview Automatic monitoring DVCC Firmware insufficient alarm: Warning 2021-02-09 16:55:56 6s
System overview Automatic monitoring DVCC Firmware insufficient alarm: Warning 2021-02-09 14:59:42 10s
MPPT SmartSolar
Pavel Richter answered ·
Thank you,
I don't use mulptiplus. I only have a DC system, DC loads
I turned off DVCC, no change.
I don't know if it's a cabling fault. Because everything worked and otherwise it didn't change. Only updated FW in MPPT and octo GX.
Any advice?
Boot the Octo GX with the previous FW and see if you still have those errors or not.
Alexandra avatar image
Alexandra answered ·
@Pavel Richter
Update the Multi itself. The DVCC firmware insufficient alarm happens sometimes when part of the system is updated but not the whole system.
https://www.victronenergy.com/media/pg/Venus_GX/en/error-codes.html Error #48
You will need an Mk3 adapter and Victron connect. Save the settings file first though. See the link for more info.
https://www.victronenergy.com/media/pg/VE.Bus_Configuration_Guide/en/firmware-updates.html
good news everyone :)
downgrage FW in octo GX helped. No more error messages.
Does anyone know what is wrong with version 2.62
2.63 is already available I don't know if I should try it? if it is possible to go back two versions to 2.60?
