First time i see this, soc rises to 100 %, while no excess solar...what could cause this?
the SOC will raise to 100% IF
1. the Bulk voltage is reached, on a multi or quattro using the internal battery monitor
2. if you have a BMV then in settings there is a charged voltage setting and the SOC will go to 100% when this setting is reached.
This is a basic senerio, in both of the above there are other side requirements that also have to be meet as well
23 People are following this question.
