Javier Moran avatar image
Javier Moran asked
Limit Discharge
Dear Community, good afternoon
Currently working in setup with an EasySolar.
I will configure it as "Keep batteries charged". This way when batteries are fully charged any PV power will be used by the loads.
In case of grid failure I would like to discharge the batteries to a certain limit and then shut the system down until grid power or solar power is available again to recharge the batteries. Is this possible?.
Thanks for your help.
Best regards,
ESS
Warwick Bruce Chapman avatar image Warwick Bruce Chapman commented ยท
I deleted my previous answer because it was wrong. I misunderstood.
0 Likes 0 ยท
nickdb avatar image
nickdb answered ยท
You can set inverter shutdown and restart soc limits in the config tool.
Javier Moran avatar image Javier Moran commented ยท
Dear nickdb, good afternoon
Thanks for your quick answer.
So there will be no conflict between ESS and this limit?
Thanks for your attention,
Best regards,
0 Likes 0 ยท
Warwick Bruce Chapman avatar image Warwick Bruce Chapman Javier Moran commented ยท
Confirmed. There is no conflict. In fact when you setup ESS, it asks you to specify 4 Dynamic Cutoff values based on different loads.
0 Likes 0 ยท
