Rob Duthie avatar image
Rob Duthie asked
ESS parallel inverters maximum power limit readings double?
For ESS setup on a CCGX with parallel Mulitplus2
For single inverter systems Maximum inverter power reads OK, when set and reads on front page of the CCGX. But for parallel systems this figure might double, for example set to 500watts max inverter power the front page reads 1000watts power approx. Is this normal? As if i set to 500watts i should get 500watts approx?
This reading is on the battery power reading as we pull power from the battery at night time or no PV.
ESS
