Hi need some help activating the feed-in limiter dc coupled ,
mppt 150/100 ver 1.54
multiplus 48/5000/70-100 ver 476
color cont. ver 2.6
color cont. ver 2.6
Hi have have setup my feed in below and all is working correctly, however to comply with the DNO application here in the UK with my energy supply I need this section of the software to be password protected is this possible ?
You do need to have the ESS assistant programmed on the Multiplus
Then in the GX menu it is:-
Settings - ESS - Grid feed in (down about 8 places) -
You should see this screen, you can then enable and set it as you would like to.
Thanks all of that is done, get the same menu but the "feed-in limiting active" stays NO, feeding in all the available power .
I have a similar setup. Do you know what conditions do need to be fulfilled for the "Feed-in limiting active:No" to become "Yes" ?
In my case, when I turn feeding-in DC coupled PV, I am exporting max of the available energy and when I set it off, I am not exporting anything.
The value set under "Maximum feed-in" does not seen to have any effect - whatever I introduce, I export the max and the "Feed-in limiting active" always stays at "No"
Hi you need to select a feed-in compatible grid code for it to work.
Thanks Maha..I do not know German to dive in the forum linked to your post...
However, I see in your snapshot that your feed-in limit is Active:Yes. Is it because of the AC-coupled part ?
Feed-in limit is active but the dc-load will not be limited for charging the batteries! So all the power of the MPPT will send to the batteries. The grid-load is restricted to 6.800 W. The max. power of the panels for the Fronius is 9750Wp and in germany 70% is the max. power which can feed in.
25 People are following this question.
