Jimmy Bergetun avatar image
Jimmy Bergetun asked
How do i install plugin in Venus-docker-grafana (Grafana plugin/panel) ?
Hi, I have installed venus-docker-grafana (Grafana) on my Rpi and everything is working perfectly. I want to add more plugins/panels , but the documentation on the victron git page /youtube video doesnt say anything about how to do this. On the Grafana lab plugin page it says to run the following command,. But i dont have the grafana-cli command on my rpi after the installation. Any other way to install these plugins ?
Use the grafana-cli tool to install TrackMap from the commandline:
grafana-cli plugins install pr0ps-trackmap-panel
grafana
paulcandelaria avatar image
paulcandelaria answered ·
Hi Jimmy,
The command must be executed in the venus-docker-grafana container and not in the Rpi OS terminal. To do this you will have to open a bash shell in the container using the following command:
docker exec -it <container_name> /bin/bash
Once you are in the container, simply execute the command:
After executing the above command, exit the bash shell:
exit
You may have to restart the container.
docker restart <container_name>
Hope it helps
