I just assembled an battery of 86 kWh. In the setup screen (ess) however the max ah that can be put in is around 65 kWh. Any tips to modify this?
No, it is a 48V system but this doesnt rally matter.
In VE configure the battery capacity has to be setup. Here it seems the max wich can be entered is about a 65 kWh, while mine is 86 kWH.
For a correct functionality i would like to have a solution for this
Please, seriously consider hiring a professional for such a large installation, if it actually is 86kWh, who can differentiate between Ah and kWh.
Oops, my bad indeed...it was a long night, i must have had a closer look. Never mind then. (I know as a professional ofcourse diffence between kwh-ah), but sleep deprivation played tricks on me
28 People are following this question.
