joeno avatar image
joeno asked
values for critical loads appear on remote console, but no loads connected to AC Out
Hi there, for some days now I´m running a new Multiplus 2 with Cerbo GX, ET340 and some 4,8 K LiFePo4 Batteries, the System is setup parallel to grid,
I try to find out why remote console shows this single value for critical loads, I´ve got no loads or devices connected to AC Out 1 or 2.
Maybe it´s an theoretical value like an internal offset, but I would like to understand exactly, what it´s telling me, or should I have to change my configuration?
Has anyone an idea?
Thanks a lot for any hint.
Joeno
ESS
ejrossouw avatar image
ejrossouw answered ·
Hi @Joeno You mention grid parallel. I assume you are running ESS. There is a setting ACOUT in use. What is it set on?
joeno avatar image
joeno answered ·
Thanks for your prompt responding, not sure if you received my first try of answering, so once again ;o)
I set AC Out from ON to OFF and the remote console doesn´t show the critical loads anymore. Everything else seems to work as before. Thanks so far!
ejrossouw avatar image ejrossouw commented ·
I am curious, it is a single phase system but you have interestingly have power on L1 and L3?
