ispookie666 avatar image
ispookie666 asked
Multiplus 24/1600 and Li Ion
I'm new here. I was planning to build a backup power supply for some critical equipment. I wanted to know if the above (Multiplus 24/1600/40) would work with a Yuasa LEV40 battery, the volatage is 30.4 (8s each cell at 3.8V) - the chemistry is Li Ion ( likely Li Manganese).
Multiplus-IILithium Battery
Rob Duthie avatar image Rob Duthie commented ·
Hi
It will work well with those batteries.
ispookie666 avatar image ispookie666 Rob Duthie commented ·
Hi
Sorry to have not got back on this, for some reason I did not get any notification.
Should I change from 8s to 7s? Any pointers on what voltages to set.
Many thanks
Rob Duthie avatar image Rob Duthie ispookie666 commented ·
Hi
Yes make it 7 in series and the top out voltage of around 4.1v if you go to data sheet
it will tell your what the charge set points are.
Hi @ispookie666
It won't work very well, because the maximum charge voltage of the multiplus is 32 volt, wich equals to 4 volt per cell.
The Yuasa LEV40 cells have very little capacity when charged to 4 volts, they need 4,1 volt for there rated capacity.
It will work better if you remove / bridge one cell and make a 7s battery
What BMS system are you planning to use?
ispookie666 answered ·
Many thanks for replying. I guess I might have to go with 7s method.
The cell has its own BMS, but I will be using an aftermarket BMS to charge and discharge it.
Unless I can use another product from Victron lineup
Just an update - I shelved the 24/1600 and went with 48/1200 - batteries as 14s
That is perfect that is the correct # of cells to use you won't have any issues.
This what is have done and works perfectly.
Rob D
NZ
