simm day avatar image
simm day asked
Looking for UK ESS Installer domestic on grid - Cryodon
Hi all,
I'm looking for an installer for a pair of Multiplus II 5000 in parallel, 2 MPPT change controls, a Cerbo GX with on grid connection, rolls battery bank - ESS with profiles set up for:
Self consumption
Charge from grid
Sell to grid
Charge from grid with reduced current (for when on emergency generator)
Ideally with it being easy to swap profiles or target battery charges levels by ssh. (I can handle the software side of things, just need to profiles setup correctly)
This will also involve a new consumer unit and some other wiring, to I would assume 19th edition regs.
I don't have the hardware yet but happy to discuss fit only or fit and supply. Solar panels will already be in place and wired (via switched and fused combiners) to where controllers to be installed. Commissioning the batteries would also be preferred
Please let me know of if you or anyone you can recommend can install this - looking for install in the early summer - assuming the lock down is over.
Thanks
ESS
ejrossouw avatar image ejrossouw commented ยท
How many kWh for the batteries? Have you considered home batteries e.g. LG Resu?
0 Likes 0 ยท
simm day avatar image simm day ejrossouw commented ยท
Rolls 5000 batteries, approx 30Kwh
0 Likes 0 ยท
Dale avatar image
Dale answered ยท
Poweri did mine in Nottingham, I can recommend Paul who installed me and is a co-owner of the company. They operate nationwide as far as I'm aware. However I looked on there website they are currently closed. I would try them they know there stuff as they specialize in renwables.
simm day answered ยท
Unofrtunately Poweri seems closed for business...
You can try https://mcscertified.com/ or https://www.flexi-orb.com/ for installers. You may however find it difficult given installers typically won't get involved / certify unless they have done a full end-to-end install of all the components.
0 Likes 0 ยท
The panels form part of the actual roof (in roof fitting) so I've had done as part of the loft install. I'm happy to discuss them installing the remaining components. I'm not interested in certification as I won't be using feed in - I'm just interested in part P/19th edition compliance and the victron settings done correctly (I'm 99% sure I could set that up myself, but would probably take me 2 days with the docs to be certain of the config - whereas I'm sure someone with the experience would find it an hour or two job)
0 Likes 0 ยท
