marian-rada avatar image
marian-rada asked
Do I have a problem with ESS?
Hi I'm Marian
My off-grid installation consists of:
Inverter MultiPlus 12/3000 / 120-50 Firmware version 465;
Venus GX Firmware version v2.33;
Battery Monitor BMV-700 Firmware version v3.10;
Controller Xantrax MMPT60x150; 8 panel 200W
PV Inverter Fronius Primo6.0-1; 15 panel 320W.
1. When installing ESS assisant whatever it is in VE config 3 is not found in VRM.
 Why? What's wrong?
2. How do I disable grid code selection Germany? I accidentally entered without a password and I cannot unblock grid Germany anymore.
I attach the screens with my settings.
Thanks
ESS
Murray van Graan avatar image
Murray van Graan answered ·
Hi @Marian Rada. It seems that you have loaded the old hub 2 assistant instead of ESS. Can you confirm?
marian-rada answered ·
I do not know, another is not in the list. Where do I get a newer one?
This path sends me to my computer and I have no assistants. How do I get a newer one?
JohnC avatar image
JohnC answered ·
Hi Marian.
If you are *really* offgrid, then perhaps the only Assistant you might need is this one (to look after the Fronius): https://www.victronenergy.com/live/assistants:pv-inverter-support
Even a backup grid input is little different to a generator input. Don't install this stuff unless you need it. Do you? Special needs?
marian-rada avatar image marian-rada commented ·
Hi JohnC
Yes I'm off-grid. But I also charge with a petrol generator through the MultiPlus occasionally when they are left without the sun.
Yes I'm off-grid. I have loaded this assistant but it is still not active in VRM.
JohnC avatar image JohnC ♦ marian-rada commented ·
If your Fronius is working/charging, then so must that assistant be. Mustn't it?? VRM itself won't show that, but Remote Console should.
Your system (the genny a giveaway) is little different to mine, except for the ac-coupled Fronius. I run neither ESS, nor any assistants, and all works well.
Perhaps best to dump/ignore the stuff you don't need.
@Marian Rada
I would recommend you to go hire a professional installer or visit a Victron training.
Are you from Germany? If yes, von wo genau? ;)
Wir (Service Team Döbeln) bieten Mitte März eine Schulung an in deran auch viel praktisch testen kann.
M.Lange
I'm from Romania. I want to do the installation myself to understand how it works. What is the purpose of this forum?
Doesn't anyone know how to disable this?
I activated "Germany" and now I can not return.
He did not ask for my password upon activation.
Instead he asks password me to disable it.
Ebrahim Railoun avatar image
Ebrahim Railoun answered ·
Good Day. Try Re installing To the latest firmware. Download firmware from Victron Proffessional. First check existing Firmware and download the latest version. First 4 digits must remain the Same. Last 3 is the Version.
