vastine avatar image
vastine asked
multiplus Self-consumption hub-1 setting
Hi there
My system is use in a camper van. sometimes connect the grid power for battery charge or ac load.
My system items below:
Multiplus
Isolation trans
CCGX
BlueSolar MPPT 150/85 VECan
VE.Bus BMS
BMV-712
Victron energy 300ah battery smart
In my case I should to use the "Self-consumption hub-1 Assistant right?
The next option is "Connect to mains,no feedback"
I live in Taiwan, so I choose the grid code option is others right?
And that option ask me password
Can sent me the password?
Thanks
ESS
Hi; hub-1 (and also its replacement, ESS) are not meant for Yachts, Vehicles and other installations with a pluggable shore connection. They are not safe in those situations
ben avatar image ben ♦ commented ·
I assume the issue is that the system can't guarantee that the plug is not hot. Is that right?
Would the recommendation change if there were no pluggable shore connection, but nevertheless the system was mobile: for example, a generator and PV, but all permanently wired?
mvader (Victron Energy) avatar image mvader (Victron Energy) ♦♦ ben ♦ commented ·
Hi Ben; yes it would; then ESS is fine
