warwick avatar image
MultiPlus II 48/3kva How to stop AC-Out-2 loads being supported by battery
I moved my geysers and laundry appliances onto as yet unused AC-Out-2 on my Multiplus today in the hope that we could make better use of massive amounts of wasted solar I have because my critical loads are too small.
The MP2 manual lead me to believe that battery power would not be used to support loads on AC-Out-2:
While unlikely that both geysers will turn on at the same time, and I could add a control device to ensure they don’t, pulling 50A out of a lead acid bank is probably not a good recipe for longevity.
My ESS was configured with a minimum SoC of 80% but seeing the above I pushed that 95% and when the batteries hit that, the inverted backed off and the geysers drew direct from the grid.
What are my options to only support the loads on AC-Out-2 with available solar and leave the batteries to only support essential loads on AC-Out-1?
ESS
I think the answer to this is, “You don’t.” and the solution is alluded to in @Murraynated’s answer on my other question about isolating critical loads. I have to install an ET112 and rather export excess solar instead of using AC-out-2.
Share
safiery avatar image
We have an application (for RV customers) whereby we turn the 240VAC hot water storage on at a specified SOC and do this on AC Output 2. Follow the assistants guidelines remembering that you have to load assistants to both turn on and turn off. For the SOC triggers, we synchronise VE.bus SOC with the Lithium battery we supply using CANbus. Its a stable and proven system.
Share
