Good Day,
Can someone explain the readings below :
Grid 232W
AC Loads 0W
Critical Loads 2827W
System on Bulk
If the im only using 232W from the Grid (assuming ) whats powering the Critical loads?
Regards
Good Day,
Grid 232W
AC Loads 0W
System on Bulk
Regards
What components do you have? I would say there is some kind of wiring or configuration problem.
Hi M.Lange,
I have a Victron Multiplus , MPPT.Venus GX and 2 Batteries in Series.
I have the Grid feed into AC IN 1
I have the Output from AC OUT 1
I have the batteries wired to the MPPT and then to the Multiplus charge terminals.
Regards
10 People are following this question.
