zman4500 avatar image
zman4500 asked
SmartSolar 75/15 MPPT High Output Voltage
Occasionally, my MPPT registers output/ battery voltage higher (15-17V) than the absorption set point of 14.4V. I also noticed just now that the stored data is different from the day it happened to now. This charger is connected to my camper roof 200W panel, to 2x100Ah lithium batteries. My BVM712 is saying the same thing, but they are connected via VE bluetooth.
This charger is labeled “Roof Solar” in the photos. First photo is a screen shot from yesterday, second is of same point in time of data, but from today.
If anyone has any insight to why this high voltage may be happening or why the stored data is “updated” after the fact, I would greatly appreciate the help!
Thank you
MPPT SmartSolar
pwfarnell avatar image
pwfarnell answered ·
Most likely you have drop in batteries that do not control the charge and the BMS is disconnecting the charge and the MPPT is not expecting this so it takes a couple of seconds for it to regulate the voltage. You need to check your BMS, perhaps one of your cells is out of balance causing the BMS to shut down or perhaps the battery is full before the MPPT goes to float. Reduce your absorption voltage to say 14.2V and see what happens.
The older the data the more it is averaged to reduce the amount of storage, so short term peaks get smoothed out.
