endurance avatar image
endurance asked
VRM PV Yield strange curve
The PV yield curve looks strange since I moved PV inverters from AC In to AC out. Peaks and lows are from timing perspective at the same time as critical load peaks.
But I also do not understand the CL graph (why only L1 - I have 3p system) and the values are not really fitting to what I see in the graph output power.
any idea? looks like a SW bug.
pv yield
For three phase you have to either make a custom graph or load a graph for each phase.
Pv looks like it is tracking then re tracking. Are you feeding back or only feeding loads?
endurance avatar image endurance Alexandra ♦ commented ·
The PV yield should be just a sum of all PV inverters (all phases). It was working fine having all Inverters on AC-In (3 phase). Only after moving to AC-Out the graph for PV yield went strange. All single PV Inverters are looking correct.
Critical load graph I never understood as no match to reality.
