Is it possable to export the curent list of alarms logs to CSV:
Instance, Device, Description, Start, Duration.
As an extraction of the usual data no.
You can separate them in the csv from a range downloaded on the advanced tab.
Under the vrm log offset column you will see it. So you can filter out all values below a certain level. (Your log interval)
OK, what is this number telling me? It appears to vary from 0 to 5000+ with a 1 second granularity. I the occasions there is a loss of contact report the number does seem to match the number of seconds it was down for but I also have high values for consecutive log entries:
4/07/2024 9:00 |
4/07/2024 9:00 |
0 |
4/07/2024 9:01 |
1 |
4/07/2024 9:02 |
1 |
4/07/2024 9:03 |
2 |
4/07/2024 9:04 |
10348 |
4/07/2024 9:05 |
10291 |
4/07/2024 9:06 |
10231 |
4/07/2024 9:07 |
10171 |
4/07/2024 9:08 |
10111 |
40 People are following this question.
