Dear Victronians,
my setup is a GX, some Multiplus II and some Smartsolar MPPTs using ESS which avoids to feed power into the grid. I'd like to turn off the MPPTs from time to time to implement an upper SOC limit. This document
shows a writable modbus variable ( "/Mode" , 774) which affects the MPPTs in the way I want. But: Is it safe to write to it often (is the state stored in a flash)?
Optimally, I'd like to set the MPPTs maximum charge current/power but there seems to be no way to do so. Is this correct?
Thank you for any advise.
Frank
