dognose avatar image
dognose asked
grid setpoint in Mode 2/3
For a tiny script, I would need to dynamically modify the grid set point. However, it seems that ESS is not accepting user-setting values on dbus, as long as it's running in ESS-Mode 2.
Switching to complete external control is something I would to avoid for this tiny script to make it as portable as possible.
Just to clearify, following value would be the "correct" one to alter?
/Settings/CGwacs/AcPowerSetPoint
ESSess settings
nickdb avatar image
nickdb answered ·
Yip, that appears static as well, matches what I have set.
I would be careful relying on this, as the change is not immediate, the inverter ramps up and down, so firing new values every second isn't going to be helpful.
dognose avatar image dognose commented ·
It now started working "out of sudden" to accept values send to '/Settings/CGwacs/AcPowerSetPoint' while remaining in ESS Mode 2. (And the docu also says this is possible in ESS Mode 2 - dunno why it didn't work earlier)
Yeah, I don't need to have the inverter to react within nanoseconds on changes, also I won't peform "big steps" there, it's main purpose is to reach a "steady" Energy flow from DC to AC:
When enabling Feed-In, the MPPTs run at full throttle, because you want to feed in, apparently. However that means, that the battery is now picking up whatever it can, even if you would prefer a lower charge current.
So, my script will now monitor the battery charge current, and when it exceeds my "feel-well" value of 210 amps, it will start to instruct the inverters to actively grid feed by manipulating the grid set point, so they can drain away another 100ish amps, leading to "lower pressure" for the batteries.
(The system could handle all the charge current well, I just don't want to have the batteries run at their limit, when there is 14 hours time to charge during summer)
What is ESS training video
ESS Quick Installation Guide
ESS design and installation manual
