App up to date. Can see regulator. 1 of 3. Others connect. This one has light flash every 6 seconds so getting interference. Followed all suggestions from manual, forum and dealer.
Light still flashing, visible in app but won't take pin or connect
Hi @Ultegra
Can you reset the pincode using PUK procedure, then try to connect and after that create a service report and post that here?
The procedure to create a service report is described here: https://ve3.nl/VictronConnect_How-to-create-a-VictronConnect-Service-Report
Kind regards,
Thiemo van Engelen
53 People are following this question.
