Matt drummond bell avatar image
Matt drummond bell asked
dbs serial usb limits
hi all. i have discovered something that i just havent time to get to the bottom of fully yet.
a couple of months ago i bought a pi 3 bplus to run with 6x daly 48 12s bms s
happy days . got working with dbs and battery agg, pulquero
since then i have bought annother pi 3 b flashed with newest update
to swap other and use different settings on charging etc etc
it only picks up a max of two usb serials
the older version picks all 6 bms
the firmware that works is 1.0.20230531 is stable although i have had to mess with charge settings to get working well.
the latest version is the latest.
i have flashed 3b with older dbs version and am curious to know if it picks up all six
i will probably continue with this until i find out which firmware version stops picking all up and see what thats all about! any ideas?
dalibms
Matt drummond bell answered ·
Tried the 3b with 1020230531
Picked up all six batteries, so I can rule out the lower model than the 3b plus .
Will try a couple of releases up next see what happens! Still no ideas anyone?
