hansdd avatar image
hansdd asked
Which setting for load output mppt 100/20?
Situation: 2x 115w victron panels, mppt 100/20, cell power agm 110ah battery. Everything works fine. Cooler is connected directly to battery. Some small led lights and 2 usb are connected to an old EBL(power/inverter unit) that chargers the battery when using ‘shore power’. The solar setup is new. Now I want to use extra usb/12v cig socket (unit has its own on/off switch) on the load output of the mppt. Mainly for phones/ipad/13650 batterycharger. Battery protection has priority. What is the preferred setting for this output in this situation? Batterylife or conventional algorithm 2 (11.8-14.0) or another? (At this time, load not in use, jumper is still in place, I will remove that before installing)
Regards,
Hans
MPPT SmartSolar
