As we are now in summer time the solar forecast is out by 1 hour.
No problem just FYI Victron guy's and girl's.
I will raise it with the team, I suspect it will take a few days to adjust.
Can you confirm what timezone is set and that the cerbo adjusted correctly?
Thank you for your quick response.
Cerbo is set to GMT Stansted Time and the time on the Cerbo and VRM are correct.
Yes i am sure it will catch up in a day or two. No worries.
Cheers.
Can't see the point of daylight savings myself. :(
Where do you see the discrepancy. I've just checked this on an installation (funnily enough, close to Stansted) and it looks right to me.
Hi @kevgermany
Between 7pm and 8pm (was 6 to 7) i will always produce 4 to 500wh but now there is 0wh predicted. I could well be misunderstanding what i am to expect so thanks for commenting but nothing to worry about I'm sure.
40 People are following this question.
