Hi there,
I have a MPPT 75/15 in a boat charging a dedicated house battery and I would like to know if I can connect the output to keep the other 2 cranking batteries charged while boat is stored.
Thanks
Hi there,
Thanks
If the batteries are all the same chemistry/voltage and your wiring is OK, yes. You might find the boat is already wired for this with a switch that connects start and house for boost when starter batteries are low.
Thanks for replying.
All batteries are light-deep cycles lead acid.
I have done the wiring for the solar and house batteries, I've got a two-way switch which is there only to isolate as I've added a combiner to allow charging of both batteries once the load is available.
there's an Anderson on the end of the load cable that I can connect to the batteries but I'm not sure what voltage to go for as usually they will be nearly full battery just needing topping up and floating....
A risk of blowing fuses in the mppt/wiring that is only rated to 20a.
The charger would only be connected to cranking batteries while the boat is parked.
I'm unsure if I have to set the load output of the charger to a certain voltage similar to the floating phase.
I usually use the boat every couple of weeks on average.
To be clear, when you say to set the short max absorption period is that for the house battery connected to the "battery" outlut or the two cranking batteries that I want to connect to the "load" output?
Thanks
52 People are following this question.
