Hendrik avatar image
Hendrik asked
My ESS system is not using my solar to run my loads, why?
Hi all I recently installed a 5k multiplus with a mppt 150/60
Ad did the ess as needed however my pv array comes on in the mornings to charge the battery's and ad soon as they are charged drop dow to 30 or 50w
And my full load is being pulled by the grid and nothing by the pvs
Please help me understand why
ESS
Jaco Reinecke avatar image
Jaco Reinecke answered ·
Did you limit the inverter's output on the VenusGX?
What did you set the charge amps at on the VenusGX?
Regards
Jaco
ejrossouw avatar image
ejrossouw answered ·
What mode is ESS set up as? Are all firmware updates applied to all devices? What is the gridsetpoint value?
