rufflivin avatar image
rufflivin asked
Multiplus 2 popping sbore breaker
My boat trips the shore power breaker when the Multiplus 2 switches to inverter mode after shore power is disconnected. If I reset the breaker on the dock all will be fine again until I disconnect 120v shore power. The 30 Amp breaker on the boat itself does not trip.
I have updated all firmware and left all other setting default for AGM house bank.
I just installed this Multiplus 2 12v on my boat. I'm only using 30amp service so only using L1
I am replacing a Magnasine inverter that worked fine.
multipluss ii
