Is it possible to connect more than one SmartSolar MPPT 75/15 to a cerbo GX device?
Yes.
There are three ve direct ports (so ve direct to ve direct), then you can still use the VE direct to usb if you need more. (Expanded by usb hub if necessary)
52 People are following this question.
