Edit a value in a alarm rule doesn't get saved after edit. Have worked before, but have been a bug for more than 3 weeks now. Workaround solution is to delete rule and add a rule with new values, but it would be nice to get this error solved.
+1 for this bug.
After adding an alarm via API, I tried to use PUT to edit the value per the official API bundle. The API response shows as if it is successful with the returned data showing the new edited values, but if I view the alarm setup in the VRM UI it still has the old value. The value specifically was for the lowhysteresis number.
The challenge is that the API doesn't seem to have a DELETE for an alarm rule so I'm stuck.
Thanks for the report, I'll pass it up to VRM team to investigate.
Hi All,
Thanks for your bug reports, the VRM team has just applied a fix and it should now be resolved.
Not quite yet... it's getting confused between notifyAfterSeconds and NotifyAfterSeconds-
Request content
{ "idDataAttribute": 442, "instance": 6, "AlarmEnabled": 1,
"NotifyAfterSeconds": 84000,
"highAlarm": 9000, "highAlarmHysteresis": 3000, "lowAlarm": 1, "lowAlarmHysteresis": 5}
Response:
dataCollection
idDataAttributeLimit
110342
idSite
199439
idDataAttribute
442
instance
6
lowAlarm
1
lowAlarmHysteresis
5
highAlarm
9000
highAlarmHysteresis
3000
AlarmEnabled
1
NotifyAfterSeconds
86400
alarmEnabled
1
notifyAfterSeconds
84000
44 People are following this question.
