t0mb0 avatar image
t0mb0 asked
Victron ESS solutions
I'm afraid this is a somewhat general query, rather that a specific technical question. I'm looking for a home battery solution for a grid-connected home with solar panels and EV, with the following objectives:
1) To time-shift cheap energy provided by Octopus Intelligent.
2) To store excess solar energy.
3) To provide backup in the event of a power cut.
Now, there are some obvious candidates (Tesla/Givenergy/etc) with this specific use case in mind. But I was considering Victron as an alternative because I have Victron kit in my camper van and know it's excellent quality hardware and (correct me if I'm wrong) I think it's less reliant in terms of day-to-day operation on some back-end cloud system, but also the price per kWh could be quite reasonable with a stack of third party batteries.
However, after reading around a bit about Victron ESS setups, I get the impression that the scenario I'm describing, whilst certainly possible, isn't exactly the natural environment that Victron solutions are designed for, which seem maybe more industrial, off-grid and marine. Is this fair to say? Would I have to work harder at the configuration and software side of things to achieve what I want?
At a minimum, I'd need a system where I have a time-based SOC target, e.g 100% overnight which would force it into charge-only mode and a target of 10% during the day where it would happily discharge down to 10%. Ideally, I'd also have some other logic which would put it into charge-only mode during cheap slots during the day, which could be home assistant based or similar.
I think this is an extremely common use case in the growing home battery market, and I'd really appreciate any pointers to my questions.
ESS
Jason - UK avatar image
Jason - UK answered ·
@t0mb0 Im basiclly doing exactly wat you state. Charging using the Octopus off-peak cheap rate, batteries provide both ESS & UPS. My whole house is on the Multiplus apart from the EV.
On the below link, on the photos section is a schemaitc of my system.
https://vrm.victronenergy.com/installation/171934/share/db6807bb
t0mb0 avatar image t0mb0 commented ·
That's awesome, thanks very much. Do I take it that on your system schematic your house is all under the "Critical Loads" box and the EV charger is the only thing under "AC Loads"?
Jason - UK avatar image Jason - UK t0mb0 commented ·
@t0mb0 Correct, everything apart from the EV charger is on the AC-Out of the Multiplus unit which means my system is both ESS, and UPS in the event of a power cut.
andy156 avatar image
andy156 answered ·
I'm the same and it works very well. Although I have my own solution the Victron ESS will do the same. Ie it will use the local solar forecast to make sure that you don't just blindly charge to 100%. It will charge up enough for your load and then leave enough room in the battery for solar.
It was a while ago but last time I looked the Tesla power wall uses the last few days to determine the weather. If that was how the weather worked we wouldn't need a load of mainframes.
atebee avatar image
atebee answered ·
Victron kit perfectly suited to what you want to achieve. The solution is less all-in-one than other manufacturers so there are a few more components required to get a complete solution.
The built-in ESS settings will do most of what you want regarding scheduled charging. More advanced stuff can be done with Home Assistant. I used this for charging in cheap Agile slots, very effective.
There is also Node-Red for any really bespoke automation requirements.
t0mb0 avatar image
t0mb0 answered ·
Some reassuring replies there, thanks very much! Sounds like a Victron ESS system can do what I want. The tricky bit might be finding an installer (I'm based in Kent).
markess avatar image markess commented ·
I used https://www.selectsolar.co.uk/, very Victron knowledgeable. National but based your way.
Note that an advantage of Victron which you don't always get from others is configurability, especially using e.g. Node-RED running on the Cerbo. Tarrifs come and go, but I'm always able to modify my system behaviour appropriately, whereas some other systems seem to struggle with this.
bladerunnervf avatar image
bladerunnervf answered ·
There is some development of 'dynamic ESS' going on in the background too, see the modifications part of the forum
