wb2 avatar image
wb2 asked
DESS Charge and discharge values in DESS Settings are not followed
Hello all,
in the DESS Settings pages I set charge and discharge values on 10kWH. System A is set to 25A.
Every time the battery discharges or charges, then it goes to the limit of the battery (15kWh) and with charging to 24A. If there is then a small non critical load extra, the (main) fuse switches off.
(Changing to e.g 5kWh charge/discharge doesn't change this, any value doesn't change the maximum charge or discharge voltages)
For one reason the charge and discharge values in DESS Settings are not considered? Is this known behavior and what to do about it? THanks
ESSdynamic essbeta
dirk-s avatar image
dirk-s answered ·
The values are only information for DESS for calculation. You have to change them in the remote console under menu DVCC and/or ESS.
The information for DESS in VRM should be the same like configured in Venus OS remote console. DESS configuration will not change this values.
wb2 avatar image
wb2 answered ·
@Dirk_S , Thanks and will do. I’ve to admit that the instructionvideo from Victron shows somewhat different information. Thanks again.
