sonnenausessen avatar image
sonnenausessen asked
Config Problems with Multiplus 2
wish everyone a wonderful day.
ccgx180124plusgritmeter.jpgwith a lot of support from you, I have been able to solve ccgx180124plusgritmeterund-akku.jpgseveral problems. What I noticed is this: My VEconfig I change with Gelblei in the Pogramteil charger I find under
Battery type: None (Photo CCGX180124plusGritmeter).
Nevertheless I changed the VEconfig several times as follows (photo CCGX180124plusGritmeterundAkku).
To solve my actual problem, I had started several attempts,
to change the ESS, and had to go into the VEconfig, where it was in every new attempt to change the ESS was noticed but not conscious.
After I solved the MP2 - with your help - from the problem with the EM24, is me this problem that the MP2 cannot save its configuration that’s why the MP2 can’t control my gel battery up to 70% of the voucher is emptied.
I look forward to your help again.
Groetjes Gerrit
Mp2 3000W, 35A, 48 V ( January 2023 new equipment received)
MPP 250V, 70A, 48 V
CCGX with latest software, guild also for the other devices.
Battery Balancer
External meters EM24
PV 6,0 kW, BMV 700 connected)
4 x 200 Ah + 4 x 100 Ah lead gel, 2 (4 x 12 V switched) 48 V
einspeisereduzierung mp2 5000 mit microwechselrichter am ac out
