glipschitz avatar image
glipschitz asked
ESS will not discharge battery
Hi brains trust,
I am having an issue where my battery will not go in to discharge in the ESS.
Victron MultiPlus II 48/5000/70.
Battery is showing all ok with no alarms in Victron and online
No alarms from the BMS
State of charge is 99%
ESS Settings all seem correct
Grid meter is reporting correctly
BMS is reporting that it is ready to discharge on both battery units connecting via RS232
I have run out of ideas on how to get this battery to discharge.
Battery units are 200AH 48v LiPoFe4 connected in Parallel via Lynx Distributor (400AH Total)
Anyone have any ideas as I am all out of them?
Thanks in advance!
Greg
ESSess discharging
netrange avatar image
netrange answered ·
Your Single Phase ESS must  be connected to the L1 from your ESS Meter !
Change the wiring ... then of will works .
glipschitz answered ·
Interesting @Netrange - thanks for that info.
I suspected that may have been the issue, however I thought it would also look at the total, rather than a specific phase.
I will try that out :)
Ok, that has been corrected now @Netrange but still won't discharge
Any other ideas?
Think I might just do a full power cycle on everything and start up the system from cold to see if that helps.
netrange answered ·
Your Inverter-Mode is Inverting ? Is Power connected to the ACin or maybe a broken fuse ...
4 comments
glipschitz avatar image glipschitz commented ·
AC-In connected to Load
AC-Out 1 connected to Fronius Inverter in AC Coupled mode
netrange avatar image netrange glipschitz commented ·
Check your Multi for working ACin in the Remote Console ... Status LED in the Picture below is OFF.
glipschitz avatar image glipschitz netrange commented ·
glipschitz avatar image glipschitz glipschitz commented ·
It's in BULK at the moment
There's a small cell imbalance which is coming down with the bulk absorption as expected.
Battery 1
Battery 2
ejrossouw avatar image
ejrossouw answered ·
What is your country code? If set to standard, it won't feed in.
4 comments
I'm in Australia @ejrossouw
When you're referring to the country code, are you meaning for the grid?
It's currently set to Australia.
ejrossouw avatar image ejrossouw glipschitz commented ·
@glipschitz Yes, that is the one. I thought the devices were no longer certified for grid parallel use there? Is the grid meter in front of ALL the house loads and what is its defined role?
glipschitz avatar image glipschitz ejrossouw commented ·
Yes, the grid meter is on the main AC feed for the property.
The defined role for the meter is "Grid"
@glipschitz I am not familiar with your meter, but know you have to configure the actual meter for single of three phase on some as well as maybe change multiphase regulation to per phase.
I'd be surprised if it makes a difference though.
netrange answered ·
Check the "Parameter" from your Battery ... Maybe the DischargeCurrent ... DCL is Set to 0 ...
And a Warning Massage ?
That all looks good to me @Netrange
netrange answered ·
Try to force the System to Feed In! . ESS ... GridSetPoint to negative ... Look if that works...
Nope, doesn't do anything. Tried that one earlier too.
netrange answered ·
Maybe a Configuration Problem with the Shelly for a 3-phase konfiguration with your 1-phase System and the ESS Setup for "all phases" ?
Perhaps, although I am only using 1 phase on the energy meter and have this at L1 reporting to Victron correctly.
If it wasn't reporting correctly to the GX, then it wouldn't be feeding the data to VRM either.
netrange answered ·
That is all based on Shelly EM3.
I am running Shelly Pro EM3. It's a completely different product.
I am running this code;
https://github.com/funkmaster86/dbus-shelly-pro-3em-smartmeter
I'll order a Shelly EM (Single Phase Device) and see if that yields a better result.
Perhaps @funkmaster86 can shed some light as to why the power meter isn't triggering the ESS as I am using his code from https://github.com/funkmaster86/dbus-shelly-pro-3em-smartmeter ? :)
Interestingly, the VRM ID of the Victron EV Charger has a fixed ID of 40.
It seems that a power meter code ALSO has a default VRM ID of 40 which is seems to be what everyones dbus-shelly code injects the value into. Only picked up on this when the EV charger integration with home assistant didn't work because of the conflicting ID.
Changing the ID in the config.ini to be 940 for the Shelly Pro 3EM does change it in VRM, but, the ESS still does not trigger. Did fix the EV charger integration though.
The mystery continues....
Still no luck after replacing the power meter.
I have gone back to the beginning and factory reset the GX and reinstalled the ESS.
The new power meter is showing up and reporting the grid power as expected
The VRM Instance is set to 41 being unique in the system
Data is showing correctly on the dashboard
Data is displaying correctly in VRM
Any ideas? I'm stumped!
What is ESS training video
ESS Quick Installation Guide
ESS design and installation manual
