geronimo22 avatar image
geronimo22 asked
MPPT behind main switch
I planned to have the main power (plus) to my MPPT switched through the main power switch in my campervan. But someone now told me that the MPPT doesn't like to see solar panels and no battery. When I'm not using the van, the panels are connected, and the battery is disconnected through the main power switch. Is this okay for the MPPT?
MPPT SmartSolar
geronimo22 avatar image geronimo22 commented ·
This is the scheme I'm using.
Michelle Konzack avatar image
Michelle Konzack answered ·
Since you have an AGM battery, I would not disconnect the MPPT, which keep the battery always full, but you should the switch to "Storrage Mode" which is some Millivots lower then the Float Voltage.
Justin Cook avatar image
Justin Cook answered ·
Do not do this as drawn. As you have it currently, the MPPT will still be providing power to the DC bus after you turn your battery bank off using the main switch, which for obvious reasons would be incredibly dangerous. Additionally, as stated in the manual for all MPPTs, the battery must be connected first, then the PV, and when decommissioning then disconnect the panels first, then the battery.
Either connect the MPPT output directly to the battery, and let your panels keep the battery topped off, or keep the MPPT as shown and add a PV disconnect so that you can turn off the PV input before disconnecting the batteries.
Thank you so much Justin, this makes perfect sense. I think I just connect the MPPT via a fuse to the battery now. That solves a lot already. Then I can reconsider adding an extra isolator from the solar panels as well. Thanks!
