I have 2 x 110ah Agm batteries in parrallel, what size fuse do I need to protect the positive charging cable back to the charger? How do I work it out? I can't get my head round the battery amps or wire amps.
Thanks in advance
Thanks in advance
12v system? 24v system? What charger model do you have?
The max the charger can fit is 16mm². So feel free to go that big as well.
Thanks for that. Yes I Will be using the 40A fuse with16mm² Wire, as I had a couple of bits just long enough.
39 People are following this question.
