O have a MPPT 75/15 with a load attached directly I never see and stats on the output load in vconnect? is this normal or dis I miss a setting Have battery Life selected for algorithm
No, they do not have a way to measure the load on the output.
It only measures current it is processing. If you want to know the DC load, install a shunt there.
At least mine seems to show a load connected directly to the controller
51 People are following this question.
