nasko73 avatar image
nasko73 asked
How to disable external control on Smart Solar MPPT 150/85 tr
Hello . Did is possible to use settings from Smart Solar to charge battery .? And turn off external control?
only way what found is if dellete ESS Assistant on Multiplus II . But then when grid is available Multiplus is turn off - inverting only if is diconected from grid
i need to use Smart Solar NOT controled from Multiplus assistant .
Did have any possibility for this ?
Thanks
MPPT SmartSolar
Alexandra avatar image
Alexandra answered ·
@nasko73
You can in the mppt itself.
Remove BMS control...
A real simple way is to remove it from the GX and set it to stand alone.
nasko73 avatar image nasko73 commented ·
I`ts controled from Multiplus II ,Not from BMS . I not found any way to disable this . I still search how to turn off external control over SmartSolar MPPT . Not know why VICTRON not allow Smart MPPT to work in standalone mode when is connected to Cerbo GX and Multiplus II
