What is the meaning of 150/35 of MPPT ? I know 150 is the max input voltage of PV. What is 35 ??
The max charger output on the DC (battery) side, at the configured charge voltage.
All neatly documented in the spec sheet.
https://www.victronenergy.com/upload/documents/Datasheet-SmartSolar-charge-controller-MPPT-150-35-&-150-45-EN.pdf
So 35A x 48V = 1680W
51 People are following this question.
