pabou38 avatar image
pabou38 asked
ESS limit charging
Hello ..
I have an ESS (Multiplus II), with both grid tied PV in parallel (ie connected to AC IN), and DC coupled PV (solar charge controller , victron mppt)
I know that the ESS will use surplus from grid tied PV to charge the battery. The mppt will obviously also charge the battery
How to interpret the ESS parameter "limit charge power". Is this the sum of mppt and grid tied PV, or just one of those ?
I need to make sure maximum charge power will not exceed my battery fuse.
Thanks ESS afficionados ..
Pascal Boudalier
ESSess settings
Alexandra avatar image
Alexandra answered ·
@pabou38
That is what DVCC is for?
https://www.victronenergy.com/media/pg/CCGX/en/dvcc---distributed-voltage-and-current-control.html#UUID-f99499ea-3700-c069-a2d2-909cbdd7006f
How it works depends on your battery and if you also have feedback on.
pabou38 answered ·
Thanks you Alexandra. Indeed. I also just noticed that when dvcc is enabled, the ESS parameter: 'limit charge power' is no longer available.
I'll try that.
What is ESS training video
ESS Quick Installation Guide
ESS design and installation manual
