Jan Urbánek avatar image
Jan Urbánek asked
One MPPT 250/100 goes to 0W after battery charged
I have two 250/100 MPPT and once is battery close to full one MPPT stil same goes to 0W. I have grid feed in for 10kW so after battery charged both MPPTs should feed the grid.
In past it worked well but now it start make this issue.
I have reset MPPTS, I have update all, check PV string for issues, no reason to do so.
If i make the consumtion in house like water warmup the 0W goes to produce but stop again. Looks like not only want to feed the grid.
MPPT SmartSolar
matt1309 avatar image
matt1309 answered ·
Hi @Jan Urbánek
I assume given it worked before you have feed in excess DC enabled.
I would maybe check the MPPT's connection to the GX device/confirm it's included within the device list. It may be the case that there's an issue with the connection to GX so MPPT just ramps down to 0 rather than only ramping down if grid export limit is being hit
Jan Urbánek answered ·
Hi, I have grid feed in from April till last month it worked.
MPPT is connected and listed in Cerbo, i have try deiferent cables and change MPPT connection order in line. Nothink change this issue. As i told when house need power or charge battery it start working but not feed in to grid.
