I want to get data from smartsolar mppt by using CanBus. I am programming stm32 and ı want to learn can ı get data with canbus or how can ı get this data is there a sample code ?
Look in the download section of Victron where you will find the VE.Direct protocol.
By default, the data are streamed as "Text" which you can directly read from the TX pin.
I use the USR-TCP232-T2 to read the data via Ethernet and Telnet...
45 People are following this question.
