joker-sk avatar image
joker-sk asked
ESS with BatteryLife and AC-Ignore
a question, if the system is set up to ignore the AC-in when SOC > 25%, what happens when the Active SOC limit (BatteryLife) is recalculated to 30%?
will the system drain the battery further to 25% (since its basically grid-lost situation) until the relay is closed again, or does the ESS override the AC-Ignore to protect the battery??
I would love to set it up in Node-Red instead of the assistant to ignore the grid, to be able to follow the ActiveSOC Limit, but that's too much for me apparently :-D
thanx
ESSbatterylifeac ignore
Alexandra avatar image
Alexandra answered ·
@joker_sk
AC ignore overrides the ESS. the two are not designed to work together.
So even if battery life increases AC ignore will stick to the 25%.
You could always have the ac ignore higher then let it ESS a bit off grid. set point 0W.
Set AC ignore to 35%/40% the min set that way if battery life raises it will allows further discharge to the battery life level, but you still work the AC ignore.
What is ESS training video
ESS Quick Installation Guide
ESS design and installation manual
