I
connected my pv string to the MPPT 250/100 48V system. The pv wire reported power 208V, I connected to the MPPT it showed no voltage, thus no charging to my battery. The negative port seems to be a problem. I could take the neg wire and test voltage showing at the wire tip and the MPPT pos port. Is there anything else I need to do to turn it ON?
System
Thanks
