123joe avatar image
123joe asked
Multible charger for one battery, possible?
I would like to know if it's possible to charge one battery with two power sources.
in my caravan, I've got a booster to charge my battery from my running car. Now I am thinking about to add a PV-Module with the SmartSolar100/20. Both connected at the same time to the battery.
When I would drive I the sun, the car would charge the battery through the booster and I would get power from the PV-moduls and SmartSolar.
Is this combination possible? Can I combine this two charger?
thanks for your advices,
Chris
MPPT SmartSolar
luphi avatar image
luphi answered ·
yes, that's possible. Make sure to configure the charging algorithm identically.
Marc Heymans avatar image
Marc Heymans answered ·
This will be an excellent way to make sure your battery is maintained. If you want to make it even better, then add a GX device to manage the charging perfectly.
123joe avatar image
123joe answered ·
Thank you for the quick response.
great to hear it's possible.
Bob K avatar image
Bob K answered ·
Yes, I do it. In my trailer, I charge my 400 Ah LiFePO4 battery bank by using the travel trailer's onboard charger and a separate Victron BlueSmart IP67 charger simultaneously. With charging algorithms set properly, both devices read the battery bank voltages properly and respond accordingly.
