I have upgraded to a Victron 100/50 from a 100/20. The 100/50 doesn’t have the two input connections for the low voltage wires i have, a positive and negative.
what should i do with those two wires.
Thanks.
Thanks.
You mean the 100/50 has no load output?
You will probably connect them to the Battery but need a Battery Protect in the line. However, do not connect an Inverter to the Battery Protect
46 People are following this question.
