Does anyone know what this yellow part on the left is called? We will probably need to order one as it has vanished and we can't connect the solar charger. (It's a new setup).
Thank you!!!
Thank you!!!
It's just an ordinary ATO fuse. You should find one in every car part shop.
Below the fuse is a jumper to set the behavior of the load output.
If you don't use the load output or you use the VictronConnect app for programming you don't need that.
Look at the manual.
We are using the VictronConnect app - but can't get the app to see the MPPT solar charger and thought maybe it was because this part was missing. I guess not and we have to keep troubleshooting.
UPDATE - apparently it's not the yellow bit, it's the bit that goes in there we are looking for. Does anyone know what this would be called?
43 People are following this question.
