harrys avatar image
harrys asked
SmartSolar selection for 6 x 30Wp panels
Hello, new to this forum.
I'm planing a solar system for our caravan currently. We try to maximize power on a small and pretty cluttered roof. The best I could achieve so far is using 6 panels (including a bypass diode each) with 30Wp each.
Entering this into Victron's configuration tool results in two recommendations depending on whether we connect the 6 in series or have 2 parallel series with 3 each:
  • 6 panels in series: MPPT 250/60
  • 2 series with 3 panels each connected in parallel: MPPT 100/15
The first one looks heavily over dimensioned and is too expensive for the purpose.
For the second one I see a major disadvantage: these 6 panels will have slightly different orientation and very different shadowing situations (antenna, AC). So using a parallel connection seems like a chaotic solution with unexpected results.
For a home solar solution I'd go for an inverter with two strings / MPPT, but this isn't a solution with Victron products to my understanding. Instead, the solution could be using two MPPT 100/15 in parallel?
Questions: pros/cons for each of the solutions beyond the above findings? Other options? For the last approach: do two SmartSolar chargers work fine in parallel and are they synchronized somehow? I saw older discussions on the later from 2019. At this point a sync feature has been planned...
Thanks for your thoughts.
MPPT SmartSolar
@HarryS
And there is also the 75/15 as well.
Depends on the VOC....
6x 30W panels is only 180w on a 12v system that is 15Amps of charge. Or did you mean to say 300W panels?
You are probably better if with pwm chargers if you are splitting them up.
harrys avatar image harrys Alexandra ♦ commented ·
The config tool calculated a 100|15 for a single 3x30 string too. But you are right - looking at the specs, two 75|15 should be fine too (VOC in range). The overall dimension is 6 x 30Wp, so 180Wp overall.
kevgermany avatar image kevgermany ♦♦ harrys commented ·
Did you also take temperature compensation into account?
