lionel92500 avatar image
lionel92500 asked
Mppt not charging
Situation
I am the Happy owner of a rec BMS. The installation is 2years old and has worked fine so far.
The installation is made of winston cells 700ah, two victon mppt (smart solar 150/60 and smart solar 100/50) and five Canadian solar panel 350w 2 for one mppt and 3 for the other one. A victron cerbo and a quattro.
All the devices are managed by the rec BMS (can).
The issue.
Since this morning, solar panel are not charging the battery although it is sunny
The Mppt give the following info
Pv 39,9v 0A 1W
Battery 13,5v 0,1A
More or less the same on each mppt.
I have rebooted the system without any change.
Analyse.
No errors on any device
As I can read the voltage of the battery and of the solar panel on the two mppt I am assuming that the connections are good. Could the issue come from the BMS sending wrong info to the mppt ?
Any ideas on where the issue could come from and how to confirm it (list of check)
I am also searching for a "plan b". i.e Removing the CAN connection so that charging from the Mppt is only based on battery voltage.
Many thanks for your help.
Regards
MPPT SmartSolar
